Level measurements
Level measurements
For level measurements are people measuring form the center of the hub to the bottom of the fender? I do that measurement and find only one inch difference front to rear and I see most level kits are 2 inch. And I'm guessing that a 2 inch lift probably only lifts a little over 1.5 inches.
wait now if you are doing this to a two wheel drive with springs it is different from doing it with four wheel drive torsion bars. What year silverado and 2wd or 4wd like country said?
With the levelin kits for 07+ 1500s, what size kit you get is how much it'll lift the front. A .75" spacer will get you 1.5" of lift, a 1" spacer will provide 2" of lift, a 1.25" spacer will provide 2.5" of lift, a 1.5" spacer= 3" of lift.
