Level measurements
Old Mar 7, 2013 | 8:22 AM
f5fstop's Avatar
Default Level measurements
For level measurements are people measuring form the center of the hub to the bottom of the fender? I do that measurement and find only one inch difference front to rear and I see most level kits are 2 inch. And I'm guessing that a 2 inch lift probably only lifts a little over 1.5 inches.
Old Mar 7, 2013 | 11:21 AM
Fishinfooleric10@aol.com's Avatar
yeah you are correct, with it level and still a smooth ride with a leveling kit, you are gonna get about inch and half.
Old Mar 7, 2013 | 12:37 PM
f5fstop's Avatar
Thanks. Figured it was the same as where I measured my H3 before raising the front.
Old Mar 7, 2013 | 9:25 PM
country_09's Avatar
You can crank more, but like said ride suffers.
Old Mar 7, 2013 | 9:37 PM
f5fstop's Avatar
No cranking, it's a 1500 series.
Old Mar 7, 2013 | 11:55 PM
country_09's Avatar
So I take it 2wd? I'm 1500 but have a 4wd with torsion bars to crank. Unless you're talkin about a 07+ 1500
Old Mar 8, 2013 | 12:54 PM
wait now if you are doing this to a two wheel drive with springs it is different from doing it with four wheel drive torsion bars. What year silverado and 2wd or 4wd like country said?
Old Mar 8, 2013 | 1:34 PM
f5fstop's Avatar
Sorry folks, it's a 2013 1500. I guess I should add that to my signature.
Old Mar 8, 2013 | 1:37 PM
f5fstop's Avatar
Sig updated....
Old Mar 9, 2013 | 12:47 AM
country_09's Avatar
With the levelin kits for 07+ 1500s, what size kit you get is how much it'll lift the front. A .75" spacer will get you 1.5" of lift, a 1" spacer will provide 2" of lift, a 1.25" spacer will provide 2.5" of lift, a 1.5" spacer= 3" of lift.
