Lube Question???
Old Apr 18, 2010 | 4:37 PM
nauticstar87's Avatar
Default Lube Question???
Alright, I'm bout to be moving to Texas. I'm leaving mid-May, and will change the oil a few days before I leave, check the trans all that good normal stuff. But, with the truck hauling roughly 4-5,000LBS, I want to grease all teh zerts i can find. What kind of grease should I use??? On my ol' ford I used whtever i had, but I care about this truck a little more than that one.
And anymore moving tips y'all have would be appreciated. I know to check the lights and the hubs on the U-haul trailer anytime I stop.
Old Apr 19, 2010 | 3:41 AM
cams 98 silverado's Avatar
best thing that comes to mind on the grease, use something a little more heavy. Do not fill to where grease pops out the boot. when you do that, you just broke the seal on the boot, creating a great pathway for moisture to creep into the inside area and rust. the way i was taught at school, was you poke the boot, if it is emptyish, squirt the grease in like 2 times, just enough until it starts to inflate, then that's it. I like using the heavier grease. oh, and while your down there, if the bushings on the sway bar aren't bad, loosen the bolts that hold em up, and squirt some grease in there too, so while your on the road those bushings don't start to squeak
Old Apr 19, 2010 | 8:17 AM
s34n's Avatar
could probably use atf oil on your bushings.
Old Apr 19, 2010 | 3:00 PM
Thanks. Guess if I can find Havoline grease I'll use that. That's what we used on the tractors and discs back home. I know how to grease 'em up, just don't what grease I should use. Being a Crew Chief has me a bit wary because some grease that we use can counteract each other if they ever met.
Old Apr 19, 2010 | 5:49 PM
therewolf's Avatar
Good luck and God speed.
Oh, yeah, when you're hauling a load, be careful of trusting the cruise control. It will only work well on flat, level roads. So if you have to deal with a lot of hills or grades, trust your foot instead.
Old Apr 19, 2010 | 6:04 PM
Yep, I know it. I'll be on I-10 most the time, all I gotta worry bout is the bridge over the Mississippi. LOL. I love the Tow/Haul button in that case. Actually works.
gas_hawg
Apr 25, 2013 8:41 AM
hopakco
12
Aug 17, 2009 8:40 PM
Dave Cover
Apr 15, 2009 4:19 PM
1604neil
May 19, 2007 9:55 AM
sredlin
Nov 1, 2006 12:50 AM
