misfire without check engine light
Old Aug 19, 2015 | 2:43 PM
mnerat555's Avatar
Default misfire without check engine light
I have a 95 Silverado with the 350 tbi. I'm getting a misfire but no light. It's fairly significant while cruising at highway speeds 60mph(1600/1700rpms) and under a load it isn't as noticeable. I have a slight intake manifold leak also but not sure that'd have Anything to do with it. Wondering what I should start with? Thanks
Old Aug 24, 2015 | 12:19 PM
mnerat555's Avatar
No one??
Old Aug 24, 2015 | 1:52 PM
burnhedge's Avatar
I can't make out what your talking about. Misfire at highway speeds?
Slight intake manifold?
Old Aug 24, 2015 | 3:16 PM
mnerat555's Avatar
Slight intake manifold leak. And highway speeds is when it's most notable but does it at all speeds.
Old Aug 24, 2015 | 4:11 PM
Phillip123's Avatar
Maybe there is no fault code stored in the Power Control Module.
Maybe you should diagnose this by monitoring knock sensor data...
Old Aug 24, 2015 | 4:12 PM
burnhedge's Avatar
If you have a known vacuum leak I'd certainly start there. More often vacuum leaks will cause high idle and surges though.
Several things can cause a miss. Catalytic converter, fuel delivery, spark/timing. If the truck is due for a tune up go ahead and do it. It doesn't cost much to replace the fuel filter, plugs,wires, rotor,cap, and coil. This will eliminate alot possible causes. Pull the distributor and check the gear for wear.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
93chevyman
Mar 12, 2010 1:13 PM
