Missing In Action
Old Sep 11, 2011 | 7:43 AM
96 Junk That Moves's Avatar
Default Missing In Action
First off I must apologize as I put this post in the wrong forum. So here goes...96 ext cab 2wd,at. 256k . This truck runs strong except it drops #7 for no reason(none that I can find) complete fresh tune up. compression good all cyls. Sometimes it runs for weeks and no problem and then it will occure days at a time. self fixes and the ses lite goes out with no reset! Fuel pump is new. Any help will be appreciated as I have little hair left to tear out at this point.
Old Sep 11, 2011 | 8:38 AM
kevinkpk's Avatar
I guess you happen to catch a code at times since you say #7. This is a misfire?
Old Sep 11, 2011 | 9:56 AM
Yes all the code says is misfire #7 . No other info
Old Sep 11, 2011 | 10:02 AM
With 256k on the clock could it be a timing chain issue? Dist shaft is within tolerance and not the least bit loose. I assume this is a mechanical problem and not related to anything vaccum or electrical.
Last edited by 96 Junk That Moves; Sep 11, 2011 at 10:05 AM. Reason: added more info
Old Sep 11, 2011 | 4:21 PM
kevinkpk's Avatar
I'd say not a timming chain, reason being (I assume it is just the one cylinder misfire?) it is just one, and the same cylinder? If it were a timming chain, I'd think it would be an over all problem with all 8.
Old Sep 11, 2011 | 5:18 PM
ukrkoz's Avatar
wait till dark and spray soapy water all over wires and distributor. report back.
2nd guess is - crack in the engine head or head gasket at #7.
Old Sep 12, 2011 | 3:32 AM
already did the water trick and anyway wires and cap are new so no cross fire or leakage. Don't believe it's a cracked head or gasket cause compression is good and it does'nt occure on a regulr basis. as I said it may go for weeks and not screw up.also the plug looks good ,nice lite tan color ,no water or oil fouling.
Old Sep 12, 2011 | 6:39 AM
shamrock246's Avatar
poppet injector sticking? thats about the milage mine had on it when #5 poppet stuck closed
Sean
97 4x4 burb
Old Sep 12, 2011 | 4:53 PM
I hate to say it but thats all I have left and taking that spyder apart is a pain. I might try some "Sea Foam" gas additive first.
Thanks
Old Sep 12, 2011 | 5:25 PM
try the Sea Foam first you can get that upgraded spider assy on amazon for about $215 i wouldn't mess with the old one
Sean
97 4x4 burb
