Motor swap no oil pressure
Old Sep 8, 2024 | 6:48 AM
Rschick4's Avatar
Default Motor swap no oil pressure
I put in a full dod delete on my 2014 5.3l silverado I changed the oil pump also, now I'm getting zero oil pressure. I pulled out oil pressure sensor crank engine and get no oil? Bad pump? Or could it be a different issue?
thanks
Old Oct 12, 2024 | 12:50 AM
jlivy's Avatar
check the oil pressure control solenoid connector and ensure there are no bent pins or corrosion. if it's ok. check resistance. pin 1 Violet/Dark Blue to pin 2 Dark Blue. should have 10-30 ohms on the male side.
keep me posted hope this helps
Old Oct 12, 2024 | 7:36 AM
Rschick4's Avatar
Thanks, I've fixed the issue. As the pump is not bolted to oil pickup tube,only pressure from pump to pan I had a bad seal so it was pulling air not oil. Not the best design by GM! Had pull the motor and reseal.
Sal Briseņo
Jan 28, 2026 10:02 AM
Thomas Neels
May 23, 2024 7:54 PM
Thomas Neels
Jun 19, 2021 1:15 PM
Thomas Neels
Jun 18, 2021 8:40 PM
Thomas Neels
Jun 18, 2021 6:50 PM
