Need Help With 4 Wheel Drive.......
Old Jan 24, 2011 | 2:18 AM
Chuey71's Avatar
Default Need Help With 4 Wheel Drive.......
Ok I'm sure this has been talked about a million times on here but I am new to the forums and haven't found what I was looking for yet. Here is my problem. I have a 91 K1500 and the 4 high isn't working. I have 4 low and the indicator light comes on but when I put it in 4 high it doesn't engage and the light doesn't come on. Can someone please help me with this.
Thanks
Chris
Old Jan 24, 2011 | 6:39 AM
fishhook86's Avatar
Could the actuator be getting weak? That was my first thought but it would probably go into hi easier if it was gonna be picky between the two..
Old Jan 24, 2011 | 8:39 AM
gotstylez's Avatar
well i would go by elmination... transfer case would be first.. does it work in 4wd low? put the truck in 4x4 low get under the truck and see if the driveshaft turns.. it shouldnt turn.. do the same with 4x4 high.. it souldnt turn if 4x4 is on..if it doesnt turn then from there i would check the actuator.. if it does turn then something is wrong with the linkage or transfer case..
Old Jan 24, 2011 | 12:25 PM
Chuey71's Avatar
Yeah 4 low is working fine
Old Jan 24, 2011 | 12:51 PM
gotstylez's Avatar
ok. do what i said above
Old Jan 24, 2011 | 6:26 PM
Chuey71's Avatar
Ok thanks davey
Billy HC
Dec 10, 2018 1:59 AM
rksorrells
Oct 30, 2012 1:20 PM
Metrostar
Mar 4, 2011 9:42 AM
Jaysonic
Mar 8, 2010 9:07 PM
subirs05
Aug 7, 2008 12:44 AM
