Need help...
Old Jun 21, 2011 | 2:54 PM
Mr.T's Avatar
Default Need help...
I have an 03 Silverado 1500. I am planning on getting a 2.5 inch leveling kit. I found a deal for a set of Mickey Thompson MTZ's on stock 16" wheels. They are 285/75/16 would they fit without rubbing issues?
Old Jun 21, 2011 | 5:02 PM
country_09's Avatar
they'll fit even before the levelin kit so yes.
Old Jun 22, 2011 | 4:09 PM
Mr.T's Avatar
I forgot to say its 2wd. Would it still fit or would i have to get a body lift?
Old Jun 23, 2011 | 10:48 AM
country_09's Avatar
with it bein 2wd it'd be tight..with it bein on stock rims it may fit with some rubbin but a body lift will definitely do the trick.
a 1.5" from zone or if you don't think that's enough then a 3" from them will work too or you could scrap the body lift and the levelin kit and find some 3" lift spindles instead of the body lift so you don't show frame and then they'll fit for sure and then you can add a little levelin kit to that if you want to go higher
Old Jun 23, 2011 | 11:13 AM
Mr.T's Avatar
I was thinking a 1.5" body lift with a 2.5" leveling kit.
Old Jun 24, 2011 | 12:05 PM
country_09's Avatar
they'll fit
be_Martinezr
Oct 6, 2014 10:19 AM
1stTahoe
Apr 19, 2012 9:44 PM
badabingman
Mar 4, 2009 8:26 PM
