Need help
Need help
I'm new to this "lift your truck" thing and I need help/ideas. I drive a 1998 silverado Ext cab 2WD. I don't want to spend a whole lot of money lifting it so I'm looking to level it. It is about 33" in the front and 34" in the back. Should I buy a 2" leveling kit or try and find a 1"? How would each one look? I just don't know where to start.
I am in the same boat as you on wanting 33's. after looking around on here I found that a 2" leveling kit will give you the room you need. It's actually a 1" block if you buy a kit from rough country but it some how gives you 2" of lift. Still not sure how that works but I have seen before and after pictures and it does. Also you can tighten your torsion bars and get 2" for a free leveling kit. Either way you go get an alignment done afterwards. Hope this helps. Good luck.
[QUOTE="Tfriend;253507"]I am in the same boat as you on wanting 33's. after looking around on here I found that a 2" leveling kit will give you the room you need. It's actually a 1" block if you buy a kit from rough country but it some how gives you 2" of lift. Still not sure how that works but I have seen before and after pictures and it does.
Thanks for the help! I was looking around but couldn't really find any for a '98. Could you post a link of any if you could? I found some on eBay but there are some that say "dose not fit Ext cab" I don't see why they wouldn't fit an exted cab...
I found one rough country leveling kit for your truck on amazon for about $150 plus shipping. I've heard good things about the brand. I personally don't like the look of a body lift myself but that would work as well. Make sure if you go that route that you get the bumper brackets and such as well.
be_Martinezr
October 6th, 2014 10:19 AM
1stTahoe
April 19th, 2012 9:44 PM
upzaw2000
HHR
December 31st, 2006 9:36 PM
