Need help on cruise control
I have a 2007 Silverado classic V6 2 wd 5spd. I want to install cruise control on it. Where can I buy it? What all does it intail? It can't be a seasy as changing the lever on the steering column?
Aby help would be GREATLY APPREACIATED....
i have a 2000 silverado and mine is powered by the cruise box which has a cable attached to a motor inside which is also attached by the cable to my throttle inder the hood. im sure it also has to be attached to your computer which may need to be professionaly done. but its just mounting the box, connecting it to your computer and you might need a new throttle **** thing. i dont know what its called but that way ou can have your gas pedal cable and the cruise cable. check into that. and any dealership would order one for you
82airborne
February 25th, 2014 9:01 AM
pcwilcox
October 21st, 2013 11:00 AM
liljoe66
August 5th, 2011 12:44 PM
hunterdmg
January 1st, 2008 1:13 PM
