Need help kinda quick
Old Apr 22, 2009 | 7:49 PM
samger2's Avatar
Default Need help kinda quick
...please.
1996 Z71...when I was taking the dash panel out to get to the radio, it came out kinda tough and when it went across the top of the steering column it busted off the hazard switch...so my hazards are now on non stop. I found the relay and pulled it...great...or so I thought.
Now everytime I step on the brake with that relay pulled my amber driving lights in the front come on.
Not sure what to do...I need to get this resolved...it's my daily driver...help!
Old Apr 22, 2009 | 8:01 PM
samger2's Avatar
update - turns out I pulled the turn signal flasher...not the hazard flasher. I can't find the hazard flasher...haynes manual says it's behind the main light switch. I looked and can't find it. Any suggestions?
Old Apr 22, 2009 | 9:37 PM
samger2's Avatar
Did a bit more research...looks like there isn't a hazard flasher and it's all built into the stalk...fantastic...another job
Old Apr 22, 2009 | 9:46 PM
suzuki-guy's Avatar
good luck cant help you out there
Old Apr 22, 2009 | 11:01 PM
northey87's Avatar
If you broke the hazard botton it will need to be replaced. Unfortunately the only way to do it is to get a whole new unit (turn signal, cruise, wiper blade, that whole thing). It is not that bad, 2hrs to replace. I had to replace my becuase my hazard button will not come un-clicked to make them come on (the opposite problem you have). I bought a cheap unit off Ebay and switched out just the hazard buttons since the rest of the "new" unit was basically a piece of junk, but I now have a working hazard lights. The buttons are not that hard to switch out, its just getting the new button thats the problem.
Old Apr 23, 2009 | 5:17 PM
samger2's Avatar
That's what I had found out...but I did some research when I got to work this morning, and found this:
http://www.automotivehelper.com/topic595263.htm
The local dealer had it in stock for around $15...got home and put it in within 5 minutes...worked perfectly.
Old Apr 23, 2009 | 8:39 PM
northey87's Avatar
Thats great! I wish I had found that before I did mine!
Outcastz89
Nov 30, 2007 12:04 AM
ramitupurs84
Jun 23, 2007 2:24 PM
ash0479
May 12, 2007 11:47 AM
Top
Follow Us
