need help wiring a stereo
Old Nov 12, 2010 | 5:09 PM
ndh87's Avatar
Default need help wiring a stereo
I've got a 90 k1500, it had the original radio and tape deck in 2 spots on the dash, i pulled the old hardware, including the CDI box and plugged in the new connector, I matched the constant on 12v wires together and the acc. 12 volt. Everything seems to be wired where it should be but the radio isnt turning on, all my fuses are good. anyone got any ideas whats wrong?
Old Nov 13, 2010 | 9:26 AM
nomad76's Avatar
is anything lighting up on the radio? could be the ground? i did thwe same swap in my 93 and it whent good. are you puting in a new radio or a used one?
Old Nov 13, 2010 | 9:45 PM
ndh87's Avatar
new head unit, i can get it to light up for about 5 seconds if i push the display or eject button, but thats it.
Old Nov 14, 2010 | 3:57 AM
tom5170's Avatar
Do you have a wire tester? I had installed a new head unit in my mine and had everything hooked up but had no power so I tested all the wires and found out my constant power was burned out. I paid 5 bucks for the wire tester at auto zone.
It also could be ur ground. Make sure you have it grounded on a clean piece of metal. Sand down to the bare metal. Dont ground it on top of painted metal.
Old Nov 14, 2010 | 9:25 PM
ndh87's Avatar
I figured it out, just had to throw a volt meter on it. Turns out i had one hot wire off the truck, not 2 like the mitchells diagram said. ran both power leads from the stereo to that and it works like a charm.
The Chevro
Oct 31, 2025 12:16 PM
davet
Feb 17, 2022 8:08 PM
thompjs
Jan 14, 2015 4:01 PM
ronboc
Dec 26, 2014 5:52 AM
Mnguyen
Jan 1, 2012 9:50 PM
