Need schematics
Can somebody please give me the schematic for the turn signal/brights/wipers switch? 97 k1500
It would be GREATLY appreciated. I have a chilton book and the schematics do not directly match my truck.
Thanks
Thanks
Close. Thank you though. More specifically i need the head lamp panel dimmer switch. And the turn signal assembly wiring, or a way to verify that there is no short in them.
The #9 fuses blow when the head light switch turned on with key on. But i didnt find any shorting to the frame.
i found the problem shorting my fuses. it was way overlooked. but it was the drl bulbs. they got loose from their casing and were spining (you could twist them with your fingers ) causing the ground and positive ends to touch
Buy a Haynes, they are MUCH better than Chilton's in particular the wiring schematics.
Davidc21a
Mar 29, 2012 6:27 PM
d1nonly34
Dec 8, 2008 2:11 PM
