New 1998 k1500, no heat....
Old Jan 16, 2014 | 10:22 PM
liers's Avatar
Default New 1998 k1500, no heat....
Picked up a 1998 k1500 that's in pretty good condition, but has some scary miles on it (220,000). Runs pretty good, just needs some little things.
The biggest thing right now is that I have no heat. Heater blows cold air on 2 and 3, and does nothing on 4 and very little, if anything, on 1.
Occasionally it will send out a burst of hot air, but 90% of the time it's just room temperature.
What's this sound like and what's the cost to fix it?
Old Jan 17, 2014 | 5:27 AM
Allan In NE's Avatar
Low coolant level or bad intake manifold gaskets would be my first guess. Blower is another matter.
Allan
Old Jan 17, 2014 | 11:10 AM
Check the heater hose going to the heater. Are they both hot? If one is much hotter than the other one then you have a clogged heater core. If they are both hot then you probably have a bad blend door actuator. You probably also have a bad blower motor resistor which is causing the different speeds not working.
Old Jan 18, 2014 | 6:14 PM
liers's Avatar
Looked at it today. Coolant was empty which fixed the heat problem. Filled it and a little while later it was empty again.
Either a leak or the intake manifold gasket I'm guessing. I'll look in the morning to see if there's any sign of coolant leaking.
I feel like if it was actually the gasket it wouldn't be emptying out that fast... Am I wrong?
The truck runs ok, but gas pedal is a little slow to respond at times. Check engine light is on, flashes at times and is solid at other times.
I know it needs a tune up, but that makes me lean towards gasket....
What do you guys think?
Old Jan 18, 2014 | 7:01 PM
Best of luck to ya Pard,
It's going somewhere and if it's not external..........
Allan
Muskovin
10
Feb 27, 2020 6:45 AM
jmarkv
Jan 24, 2012 8:21 PM
thehig
Uplander
Nov 26, 2009 9:11 PM
tumark
Apr 15, 2007 12:58 PM
