New Headlight?
New User
Awaiting E-mail Confirmation
New Headlight?
Need to replace the headlight in my 2007 classic, is this hard to do, just turned 100k on it so I might as well change both of them while I'm at it, should I look for anything new in headlights, kind of lost on this, thanks matt
The actual light or the whole housin? Pop the hood, should be 2 L shaped pins holdin it in(if it's like my 01), pull em up and the headlight housin literally falls, twist the light out, unplug it, and reverse for install
Official GM Rep
To replace a headlamp bulb, do the following:
1. Open the hood.
2. Remove the pin on the headlamp assembly by turning the pin up and pulling it straight out.
3. Pull the headlamp assembly out.
4. Unplug the electrical connector.
5. Turn the old bulb counterclockwise and remove it from the headlamp assembly.
6. Put the new bulb into the assembly and turn it clockwise until it is tight.
7. Plug in the electrical connector.
8. Reinstall the headlamp assembly.
9. Install the pin and turn it into the locking feature.
Please refer to pages 530 and 531 of the owner’s manual.
Please see attached images for a visual.
I hope this information is helpful. If you have any additional questions, please feel free to contact me privately.
Louis
GM Customer Service
garyv990
February 11th, 2015 9:52 PM
Cheverado
April 29th, 2012 11:23 AM
rukawa1one
October 10th, 2008 2:18 PM
