New member with a stalling question
Hello everyone! I just picked up a 92 1500 Tbi 5.7 and have a question about a problem I'm experiencing. The truck will start ok and soundssmooth while running, revs good in park with noexcess noise or vibration.When I put it in drive the idle drops and stalls out. When I try to start it again it will not fire and I get some vibration and noisefrom the drivetrain when it turns over (sounds like it could be coming from the tranny)?? It wont start unless I let it sit for a day or two then try again.Is there any common problems like this that these trucks have? Could the tranny be partially engaged still? Any ideas? Thanks in advance
So far only park. I've only had about 30minutes to play around with it. I will try neutral in a couple days when the weather improves. I thought I would also start with the cheapest things first vacuum leaks, pcv, Maf (I have a spare) ect? Any other cheap starting points?
bub2000sierra
May 30th, 2012 10:15 PM
Zach3713
February 2nd, 2009 4:28 PM
mmjsport
14
December 8th, 2008 8:16 PM
98Silverado1500
January 6th, 2008 1:06 AM
