New member with a stalling question
Old Feb 11, 2007 | 12:02 AM
zrad's Avatar
Default New member with a stalling question
Hello everyone! I just picked up a 92 1500 Tbi 5.7 and have a question about a problem I'm experiencing. The truck will start ok and soundssmooth while running, revs good in park with noexcess noise or vibration.When I put it in drive the idle drops and stalls out. When I try to start it again it will not fire and I get some vibration and noisefrom the drivetrain when it turns over (sounds like it could be coming from the tranny)?? It wont start unless I let it sit for a day or two then try again.Is there any common problems like this that these trucks have? Could the tranny be partially engaged still? Any ideas? Thanks in advance
Old Feb 12, 2007 | 8:10 PM
opie4487's Avatar
Default RE: New member with a stalling question
Thats a good one...did you try starting it in neutral or just park???
Old Feb 12, 2007 | 11:55 PM
zrad's Avatar
So far only park. I've only had about 30minutes to play around with it. I will try neutral in a couple days when the weather improves. I thought I would also start with the cheapest things first vacuum leaks, pcv, Maf (I have a spare) ect? Any other cheap starting points?
bub2000sierra
May 30, 2012 10:15 PM
hhwander
Mar 23, 2009 9:40 AM
Zach3713
Feb 2, 2009 4:28 PM
mmjsport
14
Dec 8, 2008 8:16 PM
98Silverado1500
Jan 6, 2008 1:06 AM
