New Tires
Old Sep 4, 2007 | 7:36 PM
dubyah1181's Avatar
Default New Tires
This may seem like a stupid question but I really don't know too much about cars. I have 16" tires on my truck right now and I'd like to get some 17" tires. Will I have to buy new rims, and will I have to change anything else?
Old Sep 7, 2007 | 10:43 AM
steve.in.roanoke's Avatar
Default RE: New Tires
No question is a dumb question if we don't know the answer. I'm disappointed no one has responded to you prior to this.
Yes the wheels will need to be changed. The "inch" measurement is the diameter of the wheel, hence a 17" tire would be too large to fit on a 16" wheel.
Go to http:www.tirerack.com to glean a ton of knowlege about tires and wheels, fitment, etc.
Good Luck, Steve
Old Sep 7, 2007 | 12:11 PM
MalibuMaxxSS's Avatar
no you shouldnt new GM trucks come stock with 16,17, 18, and 20s, unless you have a duramax..???
which case they only come 16s mostly still.....either way you should be fine with a 17, 20 maybe tight ona a duramax, and check offset, you should not have any trouble only going to a 17, but when turing depending on tire size we ran into trouble with tires rubbing...
JHarris8732
Nov 10, 2011 11:25 AM
scootr68
Jul 23, 2010 6:06 PM
06Silverado5.3LT
Sep 7, 2006 6:27 PM
