Newbi needs help please
Old Oct 17, 2007 | 7:36 PM
jimmydaleo's Avatar
Default Newbi needs help please
Hello guys. I am a newbie to the forum and need a little help. My friend has a 1997 Silverado 4x41500 with 33/12.5 16's. 80,000 milesdunlop radial rovers. He has recently has devleoped a vibration from the drivers side front tire. He immediately thought balance, had it redone, then shocks. Replaced them and then took it to a shop that said it could be ball joints as they are a little worn. had a second shop look at it and they said that not ball joints but could not pin point it. Could it be ball joints and if not what is it probably ging to be. I want to help him fix it and just want to know from the experts (other owners) that may have had the same problem.
Thanks.
Jimmy
Old Oct 17, 2007 | 9:38 PM
adam's Avatar
Default RE: Newbi needs help please
check if front brake rotors are warped
Old Oct 18, 2007 | 7:24 AM
jimmydaleo's Avatar
Thank you Adam I will do that. Anything else I might look for?
Old Oct 18, 2007 | 11:25 AM
jimmydaleo's Avatar
Any other possibilities?
Old Oct 18, 2007 | 11:36 AM
engine2's Avatar
bent wheel?
Old Oct 18, 2007 | 11:44 AM
jimmydaleo's Avatar
I was thinking that or a bent spindle
Old Oct 19, 2007 | 12:15 AM
jimmydaleo's Avatar
bump
Old Oct 19, 2007 | 12:17 AM
finny's Avatar
did you check if the tailgate was closed?
Old Oct 19, 2007 | 12:18 AM
jimmydaleo's Avatar
ORIGINAL: finny
I pretty much figure after tonight I can not expect a hell of a lot of help anymore. But what the hell. I am having fun. Maybe a group hug is needed. Anyone up for that?
Old Oct 19, 2007 | 12:32 AM
finny's Avatar
you do know it is only a matter of time till mayfair comes and rains the pictures down on us.
