Notices
No heat in cab during winter!!!
Old January 8th, 2013, 8:57 PM
  #21
branndonn's Avatar
Originally Posted by Tlindsey099
I got the part today, replacing it when ever I have time.
It's under the dash on the passenger side right???
If i remember the whole dash has to come off all the way down to the firewall then cakes and pies after that
GL
Old January 8th, 2013, 11:28 PM
  #22
Tlindsey099's Avatar
Sounds complicated.
I've only seen taking the whole dash apart on the 2000's +
After looking in YouTube and Google on mine its that plastic thing under the dash on the passenger side. pays to have the older model for once I guess.
Old January 9th, 2013, 12:03 AM
  #23
Update: went to the junk yard, only found one radiator; because mine is leaking in the corner on the plastic.
Got it home and mine is a double not a single, returning it tomorrow. fml
Old January 10th, 2013, 2:46 AM
  #24
branndonn's Avatar
Sounds complicated.
maybe theres another way , but we took the whole dash off
and about your radiator that sucked ,, hope you fix it!
Old January 20th, 2013, 4:56 PM
  #25
Radiator is in, changed the water pump and heater core. Still no heat!!
Old January 21st, 2013, 5:13 PM
  #26
is the blend door moving?
Old January 23rd, 2013, 9:06 AM
  #27
Yes it does move
Old January 24th, 2013, 8:50 PM
  #28
The blend door moves, the fan moves on high, the fluids run through all the hoses. Fluids are move in the block, out the block, in the HC and out the HC. I don't understand, I should have warm air!!!!
thehig
Uplander
November 26th, 2009 9:11 PM
tumark
April 15th, 2007 12:58 PM
Quick Reply: No heat in cab during winter!!!
