No power
Old Jul 6, 2014 | 10:26 AM
felipe398's Avatar
Default No power
Hello,
I changed my transmission seals on my truck. When I put everything back together, I didn't notice the main starter wire touching the header. When I connected the battery back it started sparking, disconnected battery, moved wire away from the header and reconnected the battery. When I turn the ignition I have no signs of life. I checked the battery and it's tested good. Replaced the starter wire to no avail. I have power to my headlights and horn only. I have no dash lights, no radio, no power elsewhere. I checked all the fuses and they are good. Could the problem be the ignition switch or computer?
Old Jul 6, 2014 | 10:30 AM
felipe398's Avatar
Also, nothing when I try to use jumper cables. When I connect the positive terminal to ground of jumper cables it sparks but nothing when I put negative to ground. Checked all the wires and they are good.
Old Jul 6, 2014 | 12:12 PM
sledge.impy's Avatar
How did you connect the negative cable ?
Old Jul 6, 2014 | 1:12 PM
Allan In NE's Avatar
It would sure help if you'd give a little more information than just "my truck". We can't read your mind.
Allna
Old Jul 6, 2014 | 5:47 PM
felipe398's Avatar
Sorry, 1990 chevy 1500 with a 305.
Old Jul 6, 2014 | 5:48 PM
felipe398's Avatar
Negative terminal to ground
Blazer311
K5 Blazer
Jul 26, 2007 6:53 PM
ToyHauler
Nov 1, 2006 10:12 PM
abeebe
Sep 27, 2006 2:20 PM
