No Power on Passenger door?
Old Nov 8, 2008 | 9:40 AM
kragar's Avatar
Default No Power on Passenger door?
I have a 2003 Ext Cab LT. All of a sudden I have lost all functions on the passenger side. All power windows/locks and mirrors do not work from either door controls. What does work on the passenger side is the turn signal indicator in the mirror. I also do not have the interior dome light coming on when Pass door is opened. The key fob has quit working as well.
Any thoughts?
thanks
Old Nov 8, 2008 | 12:42 PM
shawnvw's Avatar
Banned
Default RE: No Power on Passenger door?
sounds like a connector has come unplugged. Check in the door boot and in the door jamb....there is a fuse panelwith a harness from the passenger door
(1)
Fuse Block - Right I/P
(2)
Fuse Block - Right I/P- C2
(3)
RF Door Harness
(4)
C304
(5)
C299
Old Nov 8, 2008 | 1:16 PM
kragar's Avatar
I check the harness there and it all seems to be plugged in well.
It seems strange that the remote key fob quit working at same time? I put in a brand new battery from my Cadilac and still would not work
Old Nov 30, 2008 | 6:30 PM
cwood's Avatar
I have the same problem can seem to figure it out. I an going to try the switch cluster on passage side.
Old Sep 8, 2010 | 11:02 AM
nomind111's Avatar
did anyone have any luck??
Old Sep 11, 2010 | 5:01 PM
KEO's Avatar
KEO
check the switches on the drivers side, most cars the power comes from there and to the other doors. IF you have a bad connection at the drivers side door, it will cause the passenger door not to work.
Old Sep 20, 2010 | 7:39 PM
tool33's Avatar
Default Got Same Problem with my 2003 Denali
What did you come up with for the problem?
Old Sep 20, 2010 | 7:40 PM
tool33's Avatar
Got the same problem, What did you come up with?
Old Sep 21, 2010 | 7:01 AM
nomind111's Avatar
I have the same power all the way to the door jam no power after that. Ill check the door switch on the erar door
Old Sep 21, 2010 | 5:50 PM
KEO's Avatar
KEO
check for continuity from drivers door switch to passenger door switch, check continuity in the switches them selves.
