No Power Steering and No Power Brakes
Old Feb 22, 2011 | 8:22 PM
dcommons's Avatar
Default No Power Steering and No Power Brakes
With no warning I have no power steering or no power brakes. I checked the power steering fluid, good. I checked the brake fluid, good. Belts are good. I have no idea what to do and the truck can't be driven. Looking for some good suggestions to try. Thanks in advance for replies.
1998 K3500 Crew, 454
Old Feb 24, 2011 | 7:25 PM
fredrich03's Avatar
Are your brakes boosted with hyd pressure from power steering pump?
That would explain why they both went out at the same time.
I've seen the shaft break on the power steering pump on a couple of
GMs just inside the seal. Try removing the serpentine belt and pull on the
pump pulley with your hand, if it's broke it will come off in your hand!
Hope this helps.
Old Feb 27, 2011 | 9:22 PM
dcommons's Avatar
I took the belt off and the pulley seemed fine. It moved in and out about an 1/8 of an inch, but it seemed tight. I think it will be soon towed into a shop. It beginning to sound like $$$.
Blaine B.
12
Apr 2, 2015 12:00 PM
buddho
Feb 5, 2015 9:52 PM
HeatDet
Astro
15
Jun 9, 2010 9:18 PM
ssimpson30
Feb 25, 2010 1:40 AM
pinadenisse
Astro
Sep 24, 2009 6:49 AM
