no spark no fuel
no spark no fuel
Hi new to this forum stuff but need some help. have a 1988 chevy silverado 4x4 5.7 TBI. It had a Bad Valve On number 8 piston with only 42,000 miles on motor.Had head redone at machine shop, put head back on and now have no spark to plugs and no fuel going into TBI. Bought New CAP, ROTOR, Plugs, Plug Wires, Pickup Coil , Ignition Coil and ignition control Modual in distributor and still no fire help any suggestions. The only thing that i did wrong that probably caused the problem i have now is i started pulling the hot wire to altenator before disconnecting battery and shorted that wire on the altenator housing
ROTM Coordinator
ROTM Coordinator
Could be alot of things, Id start be checking the easy stuff like fuses & wire harness connections. There is really no sure way to test the ECM unless it is looked at by a tech.
ROTM Coordinator
ROTM Coordinator
Id contact a shop, explain your situation and they will tell you what to do. If it were me, Id break out the voltmeter and start checking all the electrical if all the fuses are ok.
Ride of the Month
May 2009
Ride of the Month
May 2009
I agree with Mike, check the electrical circuits 1st. It is possible that you fried the ECM, but I don't think that the OBD1 system would stop it from totally firing.
ROTM Coordinator
ROTM Coordinator
The dealer will probably send it in to be checked by thier guys, call & ask, maybe you mailing it to someone to be checked will save you time & $$ rather than going thru the dealer. I am just not sure who to send it to.
stdhawaii60
December 24th, 2010 11:14 AM
catill
August 30th, 2010 11:07 AM
ross_boss08
August 4th, 2008 2:41 PM
