not it!!
Old Apr 11, 2009 | 9:57 PM
suzuki-guy's Avatar
Default not it!!
I replaced the fuel line today where it was leaking and my boging down in parking lots and at stop signs continues!!! I have replaced everything!!!!!! there is only two things i havent replaced that i can think of 1)>is there two temp. sensors? The one that is on the side of the block that runs the gauge i already replaced. Is there another one that runs off the computer?2)> my evap canister is cracked can this cause this problem? is the purge valve in the evap canister? thanks guys for your help i know quite a bit about engines but this one is really stumping me!!!!
Old Apr 12, 2009 | 1:40 PM
89silverado283's Avatar
my 89 had a temp on the intake and the one on the side but thats about all i can tell you lol
Old Apr 12, 2009 | 10:06 PM
suzuki-guy's Avatar
where on the intake? i replaced the one on the side thats for the gauge
Old Apr 13, 2009 | 12:13 AM
on mine it was right next to the thermastate housing.. its right by the a/c on mine so the passenger side..its kinda small it screws right in to the intake manifold. it has a plastic clip on top of it sticks up about 2" and 1" around... the wire goes in to the main harness.. if you dont see it let me know.. maybe you could answer me some thing do i stick tranmission pluid in my transfer case or gear oil?? its the 89
Old Apr 13, 2009 | 3:26 PM
suzuki-guy's Avatar
autotrack makes transfer case fluid check at autozone or a parts store
Old Apr 13, 2009 | 4:22 PM
k.. was that where i said???
Old Apr 13, 2009 | 4:24 PM
suzuki-guy's Avatar
what autozone?
Old Apr 13, 2009 | 4:35 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Originally Posted by suzuki-guy
what autozone?
I think he meant the temp sensor.
Mine is as he said, right next to the water neck at the front of the intake manifold. Did you ever check the TPS voltage. I think you had said you replaced it twice but I don't know if you have adjusted it.
Sorry if you didn't replace the TPS, it may have been someone else.
Old Apr 13, 2009 | 4:48 PM
suzuki-guy's Avatar
i did replace the tps sensor but how do you adjust it?
Old Apr 13, 2009 | 5:01 PM
mudmaniac's Avatar
Ride of the Month
May 2009
There are a couple different types of TPSs but they all mount with 2 screws and can rotate very slightly. There are 3 wires connecting to the TPS, I can't remember the colors but there is a ground, 12 volt and TPS output voltage. At an idle you want .65 volts and at full throttle 5. volts
