O2 sensor '00 silverado
Old Nov 26, 2008 | 3:21 PM
mtnbykr's Avatar
Default O2 sensor '00 silverado
i tried to replace my O2 sensor yesterday and broke the tool!! (yes.... i was turning it the correct way) it was one of the sideways tools not a long socket. anybody know a trick to loosening the sensor? should the exhaust be hot? i'm stuck... any idea's?
thx
Old Dec 11, 2008 | 6:21 PM
jkgray80's Avatar
Default RE: O2 sensor '00 silverado
Soak it w/PB & let it sit for awhile & try again. You can buy an attachment for an air hammer from Lisle tools that works awesome.
Old Dec 11, 2008 | 8:47 PM
MDTAHOE's Avatar
Professional Mechanic
You can heat the area around the hole with a torch. You can cut the wire off and use the box end of a 7/8 wrench. You can break the sensor off and use a socket and a breaker bar. I have seen them pull the threads out of the hole when they are very tight, if this happens you can fix the hole with a spark plug tap.
kburger123
Nov 2, 2012 8:06 PM
ldearman
May 5, 2011 4:08 PM
gossimer
Nov 12, 2010 4:47 PM
jffgin
Mar 10, 2008 2:32 PM
