OBD II Trouble Code Po128
Old Mar 13, 2010 | 8:53 PM
jcolpaert's Avatar
Default OBD II Trouble Code Po128
Getting trouble code P1028. Have replace the ECT. Cleared code and less than week later code back. Temperature guage appears normal (~195 degrees when warmed up). Is there another temp sensor somewhere as the code will clear on its own if the outside temp is below 45 degrees. Manual states that ECT acts as both the temp sending unit and input for PCM. What should next step be?
2006 Silverado, 4.3L V6 with approximately 85K.
Last edited by jcolpaert; Mar 13, 2010 at 9:52 PM. Reason: Adding truck information
Old Mar 13, 2010 | 8:55 PM
xpeder's Avatar
year make model of truck
Old Mar 13, 2010 | 9:04 PM
maxxman04's Avatar
yeah, we're gonna need the vehicle specifics. typically tho, there is a sending unit for the gauge, and another sensor for the ecm.
Old Mar 13, 2010 | 9:43 PM
MDTAHOE's Avatar
Professional Mechanic
Replace the t-stat. 99% of the time it takes care of the problem.
Old Mar 23, 2010 | 12:10 PM
jcolpaert's Avatar
Thanks. Thermonstat replaced and problem solved. Suspect old thermostat was opening too soon. Thanks again!
Old Mar 23, 2010 | 7:41 PM
per's Avatar
per
Default p0128 code
replaced thermo and added coolant still have ck eng light
Mehthiro
May 20, 2020 3:14 PM
lovesmonica
Mar 22, 2011 8:02 PM
Christie08
Jul 6, 2009 3:38 PM
rsaz
Sep 6, 2008 8:58 AM
kil0
Jun 4, 2007 9:11 PM
