OBD ll port problems
Old Mar 17, 2013 | 11:55 AM
02shayne2500hd's Avatar
Default OBD ll port problems
I have a 02 Silverado 2500 HD with a 6.0l in it. I tried installing a tune on it and my obd ll port won't power up the tuner. I also tried my scan tool and it won't read either. Can anyone point me in a direction to start to correct my problem?
Old Mar 17, 2013 | 1:46 PM
Does your scan tool power up or does it power up and able to connect? If the port is dead you probably have a blown fuse. In most years the fuse also is for the cigarette lighter. It is best to check all the fuses.
Old Mar 17, 2013 | 2:54 PM
cleveland63b's Avatar
i agree check cig lighter fuse
Old Mar 17, 2013 | 3:52 PM
That was the fix. I checked all the fuses a couple days ago and the CIG lighter one was blown so I changed it and never thought to try that I never would have guessed it was on the same circuit. I have mostly been a Mopar man until recently. Thanks for the help
Old Mar 25, 2013 | 8:31 AM
paraloco's Avatar
I also noticed that my obd port was not working at all. now I'll go check that fuse. Its probably the only one I didn't check.
Old Mar 7, 2020 | 11:43 AM
Donny Bush's Avatar
Please help anybody no data communication through my OBD two truck runs fine I only have four wires in my OBD 22 are showing ground one power number two and fluctuates from .2 bolts to three volts
please help
ShaunLB84
May 24, 2014 10:37 PM
chevy_malibu
Sep 6, 2011 5:34 PM
kayster
Nov 20, 2010 2:50 PM
aquaguy
Oct 10, 2007 11:28 AM
