Oil/fuel gauges help!!!
Old May 17, 2019 | 7:39 PM
Jkisul's Avatar
Default Oil/fuel gauges help!!!
Hi everyone, I got a 1992 chevy 2500 with the 5.7 my oil pressure gauge and fuel gauge dont work. Both just stay maxed out with the truck on or off I can put the needle down with truck off and shoots right back to max as I turn it on. Would these be related to each other like there running on the same wire by any chance? It's not the cluster I tried a different on and does the same exact thing. Seems to be grounding out somewhere. Thanks
Old May 17, 2019 | 8:18 PM
kevinkpk's Avatar
Pull the fuse, then figure were the short is.Probably the sending unit.
Last edited by kevinkpk; May 17, 2019 at 8:18 PM. Reason: Probably the sending unit
Old May 17, 2019 | 8:29 PM
Jkisul's Avatar
I pulled the fuse and the gauges stay in the same spot does that matter. The fuel sending unit?
