oil question
Hi i have a 06 silverado 5.3 with 36,000 miles....i know gm says 5/30 oil. would i have any problems going to shell full synthetic 10/30?? thanks...
i have a 99 1500 silverado Z71 and i run 10/30 mobil 1 full synthetic and have friends that do the same. I have stronger oil pressure when changed comes out looking good. You should have no problem running a heavier oil.
If you live in a colder climate you may want to consider switching to 5w30 during the winter months, its easier on the engine when you have to cold start.
I use 5w30 Mobil-1 in my '04 Silverado, and it works just fine. During the coldest nights (yes, it does get cold in VA) and the hottest summer days, it does just fine.
If you use a good quality oil and change it often enough, either 5w30 or 10w30 should serve you well. Oh...don't forget to change the filter EVERY TIME you change the oil. Not doing so is like taking a shower and putting on dirty underwear.
Toby T
March 14th, 2008 5:16 PM
Big D
January 10th, 2008 6:53 PM
larry_chip
April 24th, 2007 11:46 AM
