oil question
Old Aug 10, 2011 | 5:08 PM
bill64's Avatar
Default oil question
Hi i have a 06 silverado 5.3 with 36,000 miles....i know gm says 5/30 oil. would i have any problems going to shell full synthetic 10/30?? thanks...
Old Aug 10, 2011 | 6:34 PM
Fishinfooleric10@aol.com's Avatar
i have a 99 1500 silverado Z71 and i run 10/30 mobil 1 full synthetic and have friends that do the same. I have stronger oil pressure when changed comes out looking good. You should have no problem running a heavier oil.
Old Aug 10, 2011 | 6:54 PM
kevinkpk's Avatar
Your good to go. The reason for the 5 wieght is due to cold climates. If you don't have that problem it's ok.
Old Aug 10, 2011 | 8:09 PM
country_09's Avatar
10w30 all the way
Old Aug 11, 2011 | 3:22 PM
bill64's Avatar
Thanks all......Don't have any problems with the cold,the truck lives in so. florida!.......synthetic next oil change..........thanks again.
Old Aug 11, 2011 | 8:45 PM
chevybotwie15's Avatar
You'll be totally fine.
If you live in a colder climate you may want to consider switching to 5w30 during the winter months, its easier on the engine when you have to cold start.
Old Aug 11, 2011 | 11:16 PM
JK23112's Avatar
I use 5w30 Mobil-1 in my '04 Silverado, and it works just fine. During the coldest nights (yes, it does get cold in VA) and the hottest summer days, it does just fine.
If you use a good quality oil and change it often enough, either 5w30 or 10w30 should serve you well. Oh...don't forget to change the filter EVERY TIME you change the oil. Not doing so is like taking a shower and putting on dirty underwear.
trolea1234
Mar 3, 2009 10:58 AM
Toby T
Mar 14, 2008 5:16 PM
Big D
Jan 10, 2008 6:53 PM
trush
Jan 1, 2008 9:27 PM
larry_chip
Apr 24, 2007 11:46 AM
