OIL in the Radiator...
Old Oct 11, 2010 | 11:54 AM
BALDMIKE's Avatar
Cool OIL in the Radiator...
I opened the cap on the radiator and saw oil in the water.
Hope it's just a head gasket ?
Engine is a crate 350
Question: How many shop hours does it call for to do the head gaskets and is there any other concerns I might need to worry about ?
Thanks in advance...
Old Oct 11, 2010 | 12:09 PM
2wd-K5's Avatar
more than likely a head gasket, make sure u check the cyl deck and heads with a strait edge. i have changed a set of head gaskets without power tools in 8 hrs by myself, so it may be a high hour indicator
Old Oct 11, 2010 | 1:38 PM
Mille Racer 69's Avatar
could be a head gasket, but how do you know it is oil?
have you refilled the radiator with new coolant anytime recently?
If you mix different types of coolant, an oily sludge will develope.
Maybe you are seeing the sludge if you put coolant in recently.
Also, take out your oil dipstick and take a good smell of the oil on the tip of the dipstick.
If there is a distinct smell of gasoline, your head gaskets are bad.
Old Oct 11, 2010 | 4:29 PM
2wd-K5's Avatar
no...if gas is in the oil, the rings are gone, blown head gaskets put water in the oil, and this is what i would be looking for, water in the oil, u will notice it on the dipstick, the water is under pressure and when it blows the pressure from the water makes it go where u dont want it, also blown head gaskets (at extreme fail) will **** water into the cylinders making it run on 6 cylinders
Old Oct 14, 2010 | 7:54 PM
1988scotdale's Avatar
If the vehicle is an automatic, check the transmission oil for color. If it has an engine jacket water problem the water will be in the oil sump or steaming out of the exhaust.
Old May 17, 2025 | 12:03 AM
Steyr223's Avatar
Did you ever get this figured out please let me know I have the same problem I've already changed the head gasket I don't know what else it could be thank you
Earth Rider
Dec 11, 2012 11:52 PM
butch171
Astro
Nov 3, 2011 1:50 PM
m73m95
Feb 24, 2010 11:52 AM
dmhoo29
Oct 1, 2008 4:59 PM
dieselkid
Oct 11, 2006 3:41 PM
