persistent brake lights problem
Old Jul 18, 2009 | 10:10 AM
rhino3855's Avatar
Question persistent brake lights problem
Howdy everyone,
Here's the problem: my brake lights and rear turn signals do not work. My tail lights and reverse lights work and the turn signals in the front work. I figured it would be the turn signal switch as about two months ago my emergency flashers also quit working and they are all run off of the mutlifunction. I replaced the switch but the same problem persists with the brake lights not working. I am sure I installed it correctly as the cruise control, wipers, and emergency flashers all work correctly. Any thoughts of where to look next?
The truck is a 2000 Chevy 3500 old body style.
Old Jul 18, 2009 | 8:46 PM
MDTAHOE's Avatar
Professional Mechanic
Does the third brake light work? The third does NOT run through the turn signal switch, so if it works most likely the turn signal switch is good. You can look at the brake light switch however that would not effect the turn signals. One problem I see very often in check trucks is the sockets go bad and can not carry the ground to the bulb. Visually they will look ok. You can try to add a temporary ground in the socket at the bulb (not on the wire, but where the bulb touches the socket) for testing if they work then you need new sockets. If I remember correctly it is a assembly that bolts into the tail light and is available cheap in the "HELP" section at Autozone or Advance Auto Parts.
Old Jul 19, 2009 | 10:08 AM
rhino3855's Avatar
The third brake light DOES work. I will check the grounds and see where that takes me. Thank you for your input.
PatrykKoul
Apr 26, 2023 9:14 AM
TRUCKDIVA
Jul 22, 2013 6:48 AM
DOBERDEWD
Dec 11, 2011 11:35 PM
skdevore
Aug 26, 2009 10:18 PM
cowboys
Dec 18, 2006 12:28 AM
