pinion bearing preload NEED HELP
Old May 3, 2015 | 3:25 PM
jbaesl's Avatar
Default pinion bearing preload NEED HELP
95 chevy pickup. I had to replace rear diff seal and removed my pinion flange without marking where the nut was. How do I find out how to set it right? Please help.
Old May 3, 2015 | 10:23 PM
did you measure the preload before removing it?
Old May 4, 2015 | 4:06 AM
jbaesl's Avatar
No I did not
Old May 7, 2015 | 7:48 PM
67Motorcat's Avatar
Well since you already removed it to replace the seal......
Just torque the nut back on to around 95 ft lbs.It will be close enough to get you down the road since you are not crushing a new sleeve.
You really have no other choice.It will probably be just fine.
If it starts to whine a bit,Torque it another 10 ft lbs.
ChevyJo
Dec 15, 2014 1:01 PM
Chevygirl4x4
Jan 17, 2014 6:30 AM
w4audi
Oct 22, 2011 8:39 AM
Desert Rat
Jun 4, 2008 8:27 PM
