Piston #5 misfire
Old Dec 11, 2011 | 7:18 PM
kcoch1's Avatar
Default Piston #5 misfire
I have a 96 z71 with a 5.7 vortec engine.Check engine light is on so i took it to ABC abd the computer showed piston #5 misfire.Runs kinda rough when idling.Other than that cant really tell anything is wrong.What should i check?
Old Dec 12, 2011 | 5:09 AM
96 Junk That Moves's Avatar
I had a similar deal with my 96 5.0 . With a lot of discussion and process of elimination- tune up, compresion check, fuel pressure check, and so on it turned out to be a sticking poppett valve on the injection spyder. Make sure the tuneup is good and run a few bottles of Chevron Techtron thur it .Might cure the problem if it's not a burned or sticking valve. If it turnes out to be the spyder an updated version is available on Amazon. Cost is in the $300's. Good luck and keep everyone updated.
Charlie
Old Dec 12, 2011 | 7:15 PM
kcoch1's Avatar
Thanks for the info,Ill check it out.
Old Dec 12, 2011 | 7:50 PM
Just passing on info that was passed on to me by alot of very helpful folks on this board.
buddyleno
Mar 31, 2017 8:13 AM
rdgallo
Nov 12, 2011 9:13 PM
Biggumzmcgee
Nov 15, 2009 10:51 AM
mattkwray
Feb 25, 2007 3:01 PM
