please help!!! engine loses power
Old Nov 20, 2012 | 4:24 PM
R6 Tech 413's Avatar
Default please help!!! engine loses power
hello, well my truck started acting up the other day, its a 2003 silverado 2500hd 8.1L, allison trans, crew cab. what its doing is... on the highway when i step on the gas to pass someone there is no power. it almost sounds like its not running on all cyl. if i hold the pedal to the floor after about 3 seconds the check engine light starts to flash with p0300 coming up (engine misfire detected)that is the only code that comes up, and thats the only time it will come up. if i push the pedal down when its acting up and release it before th light comes on i get no other code. even if i push the pedal lightly the truck almost starts to buck a little like it wants to die. but driving around town or on the highway with out any load its fine. ive got a new air filter and a new mass airflow sensor. but i have no idea whats going on. also in the morning before the truck gets up to temp and i hit the gas hard the tires nearly break loose and there is plenty of power. it starts to happen when the truck gets hot. can someone please point me in a direction thankyou.
Old Nov 21, 2012 | 11:44 AM
Not 1 person has any idea??
Old Nov 21, 2012 | 11:46 AM
Throttle Position Sensor maybe?
Old Nov 21, 2012 | 1:35 PM
Wouldn't that throw a trouble code?
Old Nov 21, 2012 | 1:44 PM
kevinkpk's Avatar
Maybe. Is anything in your fuel system especially fuel lines "changed" been replaced ect.? Although with forward pressure pumps, and injectors, vapor lock isn't an issue. However gas could be trying to vaporize in the fuel line if too close to a heat source, i.e exhaust manifold.
Old Nov 21, 2012 | 2:30 PM
I put on a Fitch fuel catalyst about 3 months ago, I thought maybe that could be causing it so I disconnected it completly and reset the computer and still doing the same thing.
Old Nov 21, 2012 | 2:35 PM
Might be worth checking the fuel pressure if no codes are coming up...
Old Nov 22, 2012 | 5:04 PM
67Motorcat's Avatar
Fuel pump is going south...classic symptoms.
Jack up the truck bed and swap it out.
Lose the flitch what ever it is,snake oil marketing hype sucked in another consumer,gizmo.
David Bailey
Nov 1, 2013 2:32 PM
CHEVYOK
Nov 29, 2010 4:07 AM
byronrk
Sep 12, 2008 3:13 AM
brautig
Dec 12, 2006 8:01 PM
