Please help, I,m going crazy
Old Apr 5, 2014 | 7:58 PM
darrinhammond's Avatar
Default Please help, I,m going crazy
I have a 2001 chevy silverado 1500 pickup truck. It starts up for a split second then kills. I replaced the fuel pump twice, replaced the oil pressure switch and also replaced the crankshaft sensor. I checked all fuses on the inside and outside twice. All fuses are good. The security light stays on steady so i think it the palllock system not letting it start. I tried to reset it by leaving the key on for ten to fifteen minutes but it never shuts off no matter how long you leave it on for. Also the gas guage isn't working, I have a half tank of gas but it shows empty and says low fuel on the readout. I tried to hook up 2 different scanners but they will not connect so I think the data port isn't working either. Any help would greatly be appreciated because I have been working on it for 2 days with no luck. Also, when you test the factory disarm wire in the door which is light green, it sends positive not negative. Thank you.
Old Apr 5, 2014 | 9:12 PM
Allan In NE's Avatar
Check the ignition switch.
Allan
Old Apr 7, 2014 | 11:20 AM
Chevy-guy3's Avatar
Take it to auto zone or pep boys and get them to hook up a computer reader thing and they can tell you any problems with it and locate where the problems are.. it better than guessing and spending meaningless money
moose932
Oct 15, 2022 4:56 PM
doktrred
Aug 9, 2017 9:55 PM
denn1999
Feb 14, 2011 8:02 PM
jk79
Nov 30, 2010 10:16 AM
