Please Help Soon - Security Problem
Old Jul 29, 2007 | 10:41 AM
anthem777's Avatar
Default Please Help Soon - Security Problem
Yesterday I left my truck in my driveway for app. 10 min. and did not apply the security system. I came back, attpempted to start the vehicle, and it seemed as tho the power in my truck had been turned off. My dad belives the security system thought the start was a threat to the vehicle and cut off the power. If ANYONE knows how to reset this, please let me know...for this is a major inconvieninse.
Symptoms:
Lock/Unlock remote doesn't seem to operate.
When I put the key in ignition it makes the ring noise, but when I turn the ignition nothing happens.
If I pump the break a number of times the gauges spin.
Thanks,
Colt
Extra Info:
99' Silverado 5.3L
Battery is fully charged
Old Jul 29, 2007 | 12:23 PM
RonH's Avatar
Default RE: Please Help Soon - Security Problem
Check your battery connection. Make sure your cables are clean and tight at the battery posts. A bad connection can cause what you are describing.
Old Jul 29, 2007 | 1:27 PM
Old Coot's Avatar
I agree with RonH. Especially check and clean the negative connection. If it is dirty it will work for low current pull but not for a starter.
Old Jul 29, 2007 | 2:22 PM
anthem777's Avatar
i have done all of this...i believe it is just the security system disabling the battery current.
Old Jul 29, 2007 | 2:25 PM
anthem777's Avatar
ok, i have read my truck manual...it says it is the Passlock system that is disabling the ignition...anyone know anything about it??
Old Jul 29, 2007 | 5:35 PM
golfer's Avatar
The Passlock doesn't disable the ignition , it disables the fuel pump.
Old Jul 29, 2007 | 8:39 PM
Old Coot's Avatar
Try this site and see if it helps you.
http://www.internationalelect.com/vatts.htm
Old Jul 31, 2007 | 3:16 AM
anthem777's Avatar
turns out the battery was out...cell problem...the battery reader got the wrong reading...
Old Jul 31, 2007 | 5:56 AM
golfer's Avatar
That sounds more like it since the security system has no affect on things like door locks , etc.
raven007
Sep 7, 2013 6:01 AM
colliez28
Feb 1, 2011 12:13 PM
EL GALLO
Dec 14, 2007 5:58 PM
