Power door locks
Old Nov 20, 2008 | 7:46 PM
jlbeir's Avatar
Default Power door locks
Any one know how to deactivate the automatic door lock feature on a 99 silverado ,you know the one where the doors lock when the truck hits 15 mph . The owners manual says it can be done but it does'nt tell you how! Thx
Old Nov 20, 2008 | 9:03 PM
ukrkoz's Avatar
Default RE: Power door locks
i am just lazy to go to garage, but know for sure manual says how to. you put locks into learning mode, and from that choose any option you want.
oh, well, what won't you do for a fellow trucker
go to section 2-5 in your manual. PROGRAMMABLE AUTOMATIC DOOR LOCKS. read the very last bulleted paragraph. "do the same three times to turn off the automatic door lock feature" too much to type with 2 fingers. if you don't have it in your manual, pm me, i'll copy it for u.
Old Nov 21, 2008 | 4:24 PM
shawnvw's Avatar
Banned
Subject:
Disabling Automatic (Rolling) Door Lock Feature
[align=left]
Models:
1999-2000Chevrolet and GMC C/K Models (Silverado and Sierra)[/align]
[hr]
This bulletin is being revised to update model year information, add service procedure information and change warranty information. Please discard Corporate Bulletin Number 99-08-64-003(Section08Body and Accessories).
[hr]
Some owners of the above vehicles may want to have the Automatic (Rolling) Door Lock feature disabled (turned off).
You can disable the Automatic (Rolling) Door Lock feature by either recalibrating the Body Control Module (BCM) or with the self programmable function. Use the following procedures:
[ol][/ol]
MY 1999 (VIN X)
[ol]Important:The feature may be turned off and covered under warranty on a one-time only basis. The system can be re-enabled (turned on) again at customer expense.
Connect the Tech2 to the vehicle.
Select Service Programming from the Tech2 main menu screen.
Identify the vehicle (year, type, fuel system).
Select Request Information (left soft key).
Select Reprogram Existing Module. Verify the Vehicle Identification Number (VIN).
Disconnect the Tech2 from the vehicle.
Connect the Tech2 to the Techline Terminal. Follow the terminal instructions.
Select Service Programming System from the main menu.
Select Terminal to Tech2 as the programming method.
Select Program Truck Body Controller.
Select Calibration with Automatic Door Lock Functionality Disabled.
When the action is complete, disconnect the Tech2 from the terminal.
Connect the Tech2 to the vehicle again.
Select Service Programming from the Tech2. Complete the vehicle ID.
Select the Program soft key (second from the left). When the Programming Successful screen appears, press the Exit key.
Disconnect the Tech2.
Road test the vehicle in order to confirm that the recalibration was successful. [/ol]
[ol][/ol]
MY 2000 (VIN Y)
[ol]Important:Reprogramming this function for customer preference is not warranty. Please instruct the customers to refer to their Owner's Manual operator instructions or refer to below instructions.
Beginning with the ignition in OFF position, pull back on the turn signal/multifunction lever all the way toward you and hold it while you perform the next step.
Turn your key to ON and OFF twice. Then with the key in OFF position, release the turn signal/multifunction lever. Once you do this, you will hear the lock switch lock and unlock.
You are now ready to program the automatic door locks. Once you release the turn signal/multifunction lever you will have ten seconds to begin programming. If you exceed the ten second limit the locks will automatically lock and unlock to indicate that you have left the program mode. If this occurs, to continue programming your locks go back to step 1 above. [/ol]
The following is a list of the available programming options:[align=left]
All doors lock at 24km/h (15mph), only driver's door unlocks when key is removed: Press the LOCK side of the power lock switch on the door panel ONCE, and then the UNLOCK side ONCE.[/align][align=left]
All doors lock at 24km/h (15mph), all doors unlock when key is removed: Press the LOCK side of the power lock switch on the door panel ONCE, and then the UNLOCK side TWICE. (This is the factory setting)[/align][align=left]
All doors lock at 24km/h (15mph), none of the doors unlock when key is removed: Press the LOCK side of the power lock switch on the door panel ONCE, and then the UNLOCK side THREE TIMES.[/align][align=left]
No doors lock at 24km/h (15mph), none of the doors unlock when key is removed (Turns off automatic lock feature): Press the LOCK side of the power lock switch on the door panel TWICE.[/align]You can exit the program mode any time by turning the ignition to ON. The locks will automatically lock and unlock to indicate you are leaving the program mode. If the lock/unlock switches are not pressed while in the programming mode, the respective auto lock/unlock setting will not be modified.
Old Jun 11, 2014 | 5:34 PM
Brownsville's Avatar
I have a 2013 chevy silverodo pickup, Is there a way to disable the locks that lock the doors when the truck is in park and turned off ,but keys are still in it. I use my truck a lot on the job and 9 ties out of 10 if I get out of the truck with the keys (phone and everything else) still in the truck, as soon as you/I close the doors it will automaticly lock the doors. I know on-star will open them for e, but if my phone is locked inside as well, im screwed. How do you turn this future off?
Old Jun 11, 2014 | 5:44 PM
Official GM Rep
Hey there Brownsville,
I'm sorry to hear of the difficulties that you have been experiencing with your Silverado. Please feel free to send us a private message referencing your concern if we can be of any extra assistance. I look forward to hearing from you soon!
Kristen A.
Chevrolet Customer Care
CKFords
Mar 5, 2019 2:17 AM
davbell22602
Mar 10, 2010 8:36 PM
disastro
Jul 26, 2006 9:09 PM
