POWER STEERING PROBLEMS '87 Silverado
Old Oct 15, 2010 | 8:42 AM
RyanG83's Avatar
Default POWER STEERING PROBLEMS '87 Silverado
Recently purchased 1987 Silverado as a work truck. Everything runs great with the exception of power steering. Previous owner said has a leak but works if fluid level is kept up. Replaced pump/resevoir/lines and ran great for a day before the bearings went out on pump. Replaced pump again with less tension on the belts and ran great for a week before the pressure line burst where the hose meets the metal.
Am I missing something or is it possible I just bought a bad pump followed by a bad line??? I'm hoping all I have to do is replace the line and be done with it but I'm afraid there is a problem I'm just not seeing.
Old Oct 15, 2010 | 12:34 PM
RyanG83's Avatar
Also, forgot to mention, I flushed the system but was unsure of the best way to bleed the system. Can it be done like brake lines or do I absolutely have to have one of those vacuum bleeders? It wasn't making any unusual noises after I replaced the pump so I assume there wasn't much air, if any, in the system after I flushed it.
Blaine B.
12
Apr 2, 2015 12:00 PM
bobbygrady
Aug 14, 2013 8:57 AM
dcommons
Feb 27, 2011 9:22 PM
cyberrkatz
Jan 31, 2011 8:54 AM
abeebe
Sep 27, 2006 2:20 PM
