rattling engine noise 07 Silverado
Old Sep 25, 2012 | 7:56 PM
Chevy_07's Avatar
Default rattling engine noise 07 Silverado
Hey everybody. Have an issue with something idk what tho. When accelerating around 1500 & 2200 rpm's I hear a distinct noise coming from the drivers side engine. Please help. My truck is to nice to make an annoying sound upon acceleration.
Old Sep 26, 2012 | 11:27 AM
Need more info. What does it sound like? It could be pinging which can occur when accelerating hard. Do you use high octane gas?
Old Oct 3, 2012 | 3:29 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> "oldchevy" makes a great point. Would you please provide additional information? Does it occur every time when accelerating? Or just during the day, night, etc.? Any additional information could be beneficial.
Please feel free to PM me if you prefer.
Louis
GM Customer Service
Old Oct 8, 2012 | 12:15 PM
Chevy_07's Avatar
It happens every now and then. But im not flooring it, its just steady. Alsi I find it to happen more when I just get in truck and go. Instead of letting it idle for like 5 minutes or so.
Old Oct 8, 2012 | 2:57 PM
67Motorcat's Avatar
The Cats could be getting "Loose" inside their shell.
That might explain why is does more when the truck is cold.The lower RPM harmonics can also come into play and vibrate them.
Knock on them with your hand and listen for the noise.
Old Oct 9, 2012 | 8:09 AM
Chevy_07's Avatar
Ok. And if I hear a noise, I should replace them?? I found a fix for this issue just browsing the internet obe day. Ill try an find that article and run it by you. I appreciate the help.
ddog96mn
Aug 2, 2012 10:01 PM
Hughski
Dec 2, 2007 3:28 PM
nossaint
Jul 12, 2007 11:52 AM
TahoeG8R07
Jun 20, 2007 12:21 PM
jheinen54
Nov 17, 2005 2:18 PM
