Rear brake inspection
Old Jul 26, 2007 | 8:37 PM
bevnfred's Avatar
Default Rear brake inspection
I just inherited a 1987 Silverado 3/4 ton diesel crew cab. After removing the rear tireI noticed that the brake drum and axle end flange are bolted together and a form-in-place seal is seen squeezed out of the joint. It appears that I have to remove the rear floating axle just to inspect the brakes. Is there a quick way to do this inspection? I can peek through the backing plate holes and see the self-adjusters are not near their limit but I would be more comfortable seeng the brakes and drums. How do I easily inspect the rear drum brakes?
Anyway, at some point I will need to replace the shoes and would like to know the procedure to remove the rear drums. Input or pictures would be appreciated.
w8ddwn
Jun 25, 2025 1:52 PM
oldmako
Jun 19, 2014 9:23 PM
cobalt07
Cobalt
Jul 2, 2008 9:01 PM
blazerman
Apr 6, 2008 6:46 PM
tampc
Oct 26, 2007 6:34 PM
