rear brakes arent working
I just replaced the master cylinder, bled the fronts and now there is no action on my rear brakes at all. Does anyone out there have a direction they can point me in?
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Well fluid does have to travel farther to get to the rear, are you sure you bled them enough?
Maybe go to an auto parts store and get a mighty vac, pump it to a good vacuum, then try
Bleeding 1 more time.
Also for bleeding, I find it more efficient to press in brake, open brake nipple, close brake nipple, then release the brake.
And also do not pump the brake pedal, you will turn a couple of large bubbles into hundreds of
Smaller bubbles and the smaller the bubble the harder it is to get out.
So my suggestion is to get a mighty vac, plug it in and bleed it a bit more.
Technician!
June 13th, 2014 8:29 AM
JRich_taco
August 31st, 2013 12:16 AM
Mille Racer 69
December 8th, 2010 8:26 PM
