rear end
Old Feb 10, 2011 | 7:38 PM
hondaman's Avatar
Default rear end
I just bought a 2001 silverado z71 4x4 with 5.3 i need to know how to tell what rear end is in it and if its a limited slip or what it is.Any help please
Old Feb 10, 2011 | 8:17 PM
tswiczko's Avatar
If you look in the glove box there are a bunch of build codes .
I know G80 is the Gov Lock locking differential I believe GT4 is the 3:73 gears as to what the others are
RPO CODE DESCRIPTION
RATIO
F16 TransAxle Final Drive
2.53
F17 TransAxle Final Drive
2.84
F18 TransAxle Final Drive
2.65
F25 TransAxle Final Drive
3.32
F29 TransAxle Final Drive
2.82
F36 Axle Front
2.19
F45 Axle Front
2.93
F47 Axle Front
2.73
F57 Axle Front
3.15
F62 TransAxle Final Drive
2.39
F67 TransAxle Final Drive
3.19
F68 TransAxle Final Drive
3.45
F75 TransAxle Final Drive
3.18
F77 TransAxle Final Drive
3.73
F79 TransAxle Final Drive
2.97
F82 TransAxle Final Drive
3.23
F83 TransAxle Final Drive
3.05
F90 Axle Front
2.73
FA0 Rear
5.77
FA1 Rear 2 SPEED
4.88/6.94
FA2 Rear 2 SPEED
4.88/6.94
FH5 TransAxle Final Drive
2.81
FH6 Axle Front
3.64
FH7 TransAxle Final Drive
4.12
FH8 Axle Front
2.40
FH9 TransAxle Final Drive
2.60
FJ1 Axle Front
4.18
FJ2 Axle Front
3.74
FJ3 TransAxle Final Drive
3.35
FJ4 Axle Front
4.53
FJ5 Axle Front
4.19
FJ7 Axle Front
4.56
FP0 TransAxle Final Drive
2.55
FP1 TransAxle Final Drive
2.72
FP2 TransAxle Final Drive
3.58
FP3 TransAxle Final Drive
2.73
FP4 TransAxle Final Drive
2.69
FP5 TransAxle Final Drive
2.95
FP6 TransAxle Final Drive
3.54
FP7 TransAxle Final Drive
3.73
FP8 TransAxle Final Drive
3.54
FP9 TransAxle Final Drive
3.54
FQ2 TransAxle Final Drive
3.48
FQ3 TransAxle Final Drive
2.86
FQ4 TransAxle Final Drive
3.57
FQ6 TransAxle Final Drive
4.12
FQ8 TransAxle Final Drive
2.96
FQ9 TransAxle Final Drive
3.21
FR2 TransAxle Final Drive
2.93
FR3 TransAxle Final Drive
3.69
FR6 TransAxle Final Drive
3.84
FR7 TransAxle Final Drive
3.95
FR8 Axle Front
4.17
FR9 TransAxle Final Drive
3.29
FV0 TransAxle Final Drive
3.67
FV1 TransAxle Final Drive
3.72
FV2 TransAxle Final Drive
4.18
FV3 TransAxle Final Drive
3.11
FV4 TransAxle Final Drive
3.71
FV5 TransAxle Final Drive
4.19
FV6 TransAxle Final Drive
4.24
FV7 TransAxle Final Drive
4.29
FV8 TransAxle Final Drive
4.31
FV9 TransAxle Final Drive
4.53
FVO TransAxle Final Drive
3.67
FW2 TransAxle Final Drive
3.06
FW3 TransAxle Final Drive
4.02
FW4 TransAxle Final Drive
3.89
FW5 TransAxle Final Drive
4.10
FW6 TransAxle Final Drive
3.42
FW7 TransAxle Final Drive
3.83
FW8 TransAxle Final Drive
4.28
FW9 TransAxle Final Drive
3.43
FWS TransAxle Final Drive
4.10
FX1 TransAxle Final Drive
3.94
FX2 TransAxle Final Drive
2.66
FX4 TransAxle Final Drive
3.35
FX8 TransAxle Final Drive
3.61
FY1 TransAxle Final Drive
2.36
FY3 TransAxle Final Drive
3.79
FY5 TransAxle Final Drive
3 52
G11 TransAxle Final Drive
2.56
G44 Axle Rear
3.07
G72 Axle Rear
2.14
G75 Axle Rear
3.62
G76 Positraction Rear
G80 Axle Positraction, Limited Slip
G81 Positraction Rear Axle
G82 Axle Rear
4.56
G84 Axle Rear
4.10
G86 Axle , Rear, Limited Slip
G87 Ring Gear, 8.50 Inch
G89 Ring Gear, 7.50 Inch
G90 Rear
3.15
G91 Special Highway Rear Axle
3.08
G94 Axle Rear
3.31
G96 Axle Rear
3.55
G97 Axle Rear
2.73
GH0 Axle Rear
3.54
GH2 Axle Rear
2.29
GH3 Axle Rear
2.77
GH4 Axle Rear
2.92
GH7 Axle Rear
2.73
GJ1 Axle Rear
5.38
GJ2 Axle Rear
5.13
GK7 Axle Rear
4.78
GK8 Axle Rear
4.33
GK9 Axle Rear
4.63
GL0 Axle Rear
5.13
GL3 Axle Rear
6.17
GM1 Axle Rear
2.59
GM2 Axle Rear
3.44
GM3 Axle Rear
3.45
GM4 Axle Rear
3.67
GM5 Axle Rear
3.89
GM6 Axle Rear
4.22
GM7 Axle Rear
3.68
GM8 Axle Rear
2.56
GN9 Axle Rear
4.11
GS1 Axle Rear
2.73
GS3 Axle Rear
3.73
GS4 Axle Rear
3.70
GS5 Axle Rear
4.11
GS6 Axle Rear
4.56
GS8 Axle Rear
3.94
GT1 Axle Rear
2.56
GT2 Axle Rear
2.29
GT4 Axle Rear (DUP WITH 5 X 1)
3.73
GT5 Axle Rear (DUP WITH GT8)
4.10
GT7 Axle Rear
3.33
GT8 Axle Rear (DUP WITH GT5)
4.10
GU1 Axle Rear
2.41
GU2 Axle Rear
2.73
GU3 Axle Rear 2.93
GU4 Axle Rear
3.08
GU5 Axle Rear
3.23
GU6 Axle Rear
3.42
GU7 Axle Rear
2.77
GU8 Axle Rear
3.90
GU9 Axle Rear
3.91
GV0 Axle Rear
3.55
GV1 Axle Rear
2.73
GV2 Axle Rear
5.83
GV3 Axle Rear
3.08
GV4 Axle Rear
3.36
GV5 Axle Rear
3.55
GV7 Axle Rear
4.11
GV8 Axle Rear
2.72
GV9 Axle Rear
4.25
GW2 Axle Rear
2.56
GW3 Axle Rear
2.56
GW4 Axle Rear
3.31
GW5 Axle Rear
2.73
GW6 Axle Rear
3.27
GW8 Axle Rear
4.10
GW9 Axle Rear (DUP WITH GU3)
2.93
GX1 Axle Rear
3.70
GX2 Axle Rear
3.07
GX3 TransAxle Final Drive
3.33
GX4 Axle Rear
3.75
GX5 Axle Rear
4.09
GX6 Axle Rear
3.53
GX8 TransAxle Final Drive
3.74
GY2 Axle Rear
3.31
GY3 TransAxle Final Drive
4.29
GY4 Axle Rear
4.53
GY5 Axle Front
3.65
GY7 TransAxle Final Drive
4.18
GY9 Axle Rear
4.31
GYS TransAxle Final Drive
3.65
H01 Axle Rear
3.07
H04 Axle Rear, SINGLE SPEED
4.11
H05 Axle Rear
3.73
H12 Axle Rear, 21000 LBS, EATON 21065S, SINGLE SPEED
H42 Axle Rear
6.17
H43 Axle Rear
5.43
HA3 Axle Rear, SINGLE SPEED
5.29
HC4 Axle Rear
4.56
HC7 Axle Rear, 7500 LBS, SINGLE SPEED
5.13
HC8 Axle Rear, SINGLE SPEED, TRUCK
3.21
HC9 Axle Rear
5.13
HE3 Axle Rear, 3500 LBS, SINGLE SPEED,
3.07
HE4 Axle Rear
3.40
HF7 Axle Rear, 10000 LBS, DANA 70, SINGLE
4.56
HF8 Axle Rear
4.88
HJ1 Axle Rear
4.55
HJ2 Axle Rear
5.86
HJ3 Axle Rear
4.75
HJ4 Axle Rear
6.50
HJ5 Axle Rear
5.57
HJ6 Axle Rear
4.78
HJ7 Axle Rear
4.88
HK1 Axle Rear
2.87
HK3 Axle Rear
6.14
HK9 Axle Rear 10000 LBS, SINGLE SPEED
5.86
HO4 Axle Rear
4.11
HO6 Axle Rear
4.63
Old Feb 10, 2011 | 8:20 PM
tswiczko's Avatar
Did your rear end grenade?
Old Feb 10, 2011 | 8:45 PM
hondaman's Avatar
no its makes a noise in 2wd on snow if it spins then grabs again it makes a popping noise every time it grabs.
Old Feb 10, 2011 | 8:57 PM
tswiczko's Avatar
The gov lock is not the average locker it has a set of weights that cause pressure to be put on the clutches and over a certain speed about 20 mph they release and act like an open carrier.
Because it is mechanically driven it doesn't require friction modifiers like spring loaded differentials..
Unfortunately mine grenaded about 2 weeks ago in my 00 silverado( 178,000 miles)
An after market replacement is cheaper than a factory and probably more dependable but at the moment I don't have that kind of money so I am waiting for the one I bid on at e-bay
Start searching the threads for gov. lock here and you will find a lot of information
hardbalance
Apr 30, 2015 10:57 PM
TASpinney9110
Mar 15, 2011 5:54 PM
hydrodriver
Astro
Dec 11, 2010 8:52 AM
BWEST
Dec 18, 2005 11:44 PM
