Is the rear end blown??
Old Mar 15, 2010 | 2:47 PM
  #51
maxxman04's Avatar
you would probably have to change out the brake proportioning valve. ujoints might be different as well as the width of spring perches.
Old Mar 15, 2010 | 2:53 PM
  #52
nauticstar87's Avatar
Your 2000, is it the old body style like a 95, or is it like a 03. 2000 was sort of a cross over year, and I'm not 100% on which body style you have.
Old Mar 15, 2010 | 2:56 PM
  #53
halftonornone's Avatar
its new body style.will the drive shaft hook to an older one i dont care about havin drum brakes and can handle switchin it over..
Old Mar 15, 2010 | 2:58 PM
  #54
If it doesn't, I can almost guarntee teh yokes will swap.
Old Mar 15, 2010 | 3:05 PM
  #55
and i should be able to use the yoke from my junk rear end.?
Old Mar 15, 2010 | 3:06 PM
  #56
Yes, if you have to.
Old Mar 16, 2010 | 3:19 PM
  #57
okay so does any one know if 3:73 gear kit from an older style will work... sorry to keep buggin ya guys..
Old Mar 16, 2010 | 3:34 PM
  #58
That I don't know... Are you trying to rebuild your rearend???
Old Mar 16, 2010 | 4:09 PM
  #59
ya i think me and a buddy are gonna tackle it..it really cheapest way out. i found a set online for 140 and a guy on craigslist for 50 bucks brand new.. but i need to figure out id it will work...
Old Mar 16, 2010 | 4:33 PM
  #60
maxxman04's Avatar
i would strongly recommend having someone who knows how to do it. the gears have to be shimmed just right or you will blow the new gears out real soon. there are specs that absolutely have to be figured out and dialed in for each gear set. you can't just throw them in and go.
