Replaced fuel pump, now what?
Old Jun 22, 2007 | 11:04 PM
TravisJL's Avatar
Default Replaced fuel pump, now what?
So, I have a 2000 Z with the 5.3. I ran the truck out of gas like a dip**** and had to replace the fuel pump. I yanked the bed off, replaced the pump with a new one ($300, REDICULOUS). I went ahead and changed the relay/fuse and filter while I was wrenching. Now the pump won't pump. It is the second brand new pump I put in her. I had the same problem with the 1st pump I bought and assumed the pump to be faulty. I bought a multimeter only to find that I'm not getting power to the pump. I can't figure out why. Any suggestions? I've tried "reseting" the sytem by disconnecting the neg. battery cable for some time, then reconnecting it.
Old Jun 23, 2007 | 7:20 AM
golfer's Avatar
Default RE: Replaced fuel pump, now what?
You might have to start tracinig the wiring for open ,shorted , or corroded wiring Check the fuse as well..
Old Jun 23, 2007 | 11:55 AM
TravisJL's Avatar
The wiring all seems fine. Looks stock. I can't help but think it's some sort of computer problem
Old Jun 24, 2007 | 9:28 AM
golfer's Avatar
It's possible but I would be surprised.
Have you checked at the relay to see if there is power to and from it ?
Old Jun 25, 2007 | 3:50 PM
ZX1100F1's Avatar
You can't test wires by looking at them; break out the old multimeter and go to town.
mangomanj
Aug 17, 2014 9:51 PM
scottkern3
Dec 7, 2009 7:53 PM
dmischief78
Nov 21, 2007 8:41 PM
ashortkidVW
Apr 7, 2007 10:54 PM
