Reverse Blows Turn Signal Fuse
Old Apr 14, 2010 | 3:05 PM
BacktoChevy's Avatar
Default Reverse Blows Turn Signal Fuse
Hi All,
I recently purchased a 96 Silverado - V6 5 speed 4x4 Short box/cab. When I had the shop swap my summer rims/tires for winter, my turn signals stopped working. When I replace the fuse, everything works perfectly. As soon as I put it in reverse, it blows the fuse.
I have already gone through the back half of the truck wiring harness...
- disconnected the tail lights
- disconnected the tow hitch lights
- disconnected to auxiliary LED lights (came with the truck)
- disconnected the entire wiring harness for the rear of the truck.
Each time I tested the reverse and it still blows the 20AMP fuse. I can pull the fuse and reverse then put it back in and the turn signals work (obvious but just in case )
I'm lost for ideas on where to search next?
Has anyone else had this issue before? I'm getting annoyed with having to pull the fuse out each time I reverse.
Thanks!
Old Apr 14, 2010 | 4:29 PM
xpeder's Avatar
got a short some where check the wires
Old Apr 15, 2010 | 7:03 AM
Could there be a short in the switch that initiates the reverse lights? if so, where is that switch? I took the rubber off the shifter to see where it is on the transmission but I couldn't see it...
Do the wires go through the frame of the truck or on the outside in a bundle?
Old Mar 26, 2011 | 2:48 PM
joeffemt's Avatar
Talking New reverse light switch repaired the problem for me.
My 92 K1500 did the same exact thing by blowing the turn signal switch every time you put the truck in reverse, and a new reverse light switch from Napa Auto Parts repaired the problem for me. The switch screws into the left side of the transmission of mine, which is a 5 speed mannual.
tampaviking
May 1, 2023 10:36 AM
fishingpro77
HHR
Aug 4, 2016 12:44 AM
jbyus@live.com
Sep 1, 2014 12:06 PM
RomanGuzi
Oct 2, 2011 11:40 AM
