rough idle
Old Jun 17, 2009 | 3:59 PM
jk@umd's Avatar
Default rough idle
Hi, I'm new to the forum. I've got a 2007 Silverado 2wd, 4.8L v8. For the most part it rides great except that it has a consistently rough idle. It's not extreme by any means but at the same time it's definitely noticeable. I'm going to change the plugs this weekend to see if that makes a difference. But I read somewhere that this is not an uncommon problem with these engines and that GM is aware of it but has no fix. Does anyone know if this is true? Any other suggestions? Thanks
Old Jun 17, 2009 | 4:35 PM
racerx55's Avatar
does it seem like more of a slight surge or a missifre? my 5.3L doesnt idle exactly smooth all the time. nothing really does.changing plugs most likely isnt gonna fix it. i wouldnt spend your money considering how much they cost. IMO i think its the fact that they have a pretty good sized cam lift and longer duration for stock and they just tend to not idle perfectly smooth.
Old Jun 17, 2009 | 5:18 PM
jk@umd's Avatar
I would say it feels more like a misfire, but once in a while I definitely also feel a slight surge as well. From what you say and from what I read on carcomplaints.com it sounds like it's most likely a manufacturing defect but in the end not a very serious one. Do you think it would it be worth while to clean the EGR valve? Thanks for the input
Old Jun 17, 2009 | 5:22 PM
desrtrat's Avatar
i would clean the TB first. don't take many miles for them to carbon up. also while your at it, clean your maf while you have the air intake tube off. depending on your miles, 1-2 cans of Seafoam in your fuel tank and see if that helps..
good luck..
Old Mar 14, 2012 | 9:59 PM
xfbi's Avatar
Did you solve the odd idle problem ? Thanx dalr
macmommy
Apr 22, 2020 1:23 PM
Sethyates72
Feb 1, 2014 7:53 AM
bhamjd
Feb 3, 2006 12:26 PM
egut125
Dec 1, 2005 9:41 PM
