rpm fluctuation
Old Mar 11, 2012 | 7:50 PM
Fishinfooleric10@aol.com's Avatar
Default rpm fluctuation
I have a 99 z71 with the 5.3 and I have never really noticed this until i got exhaust in July. I thought i could see the tach moving up and down a little bit but the exhaust made to where i could here it, so i know the exhaust didn't do it. It was one of those things that i would turn the radio up so i didn't have to hear it but now it's just aggravating. When driving only between about 45 to 55 my truck almost make a sound like im peddling. It doesn't feel like transmission is slipping or anything, it's not real fast just a lope. I did a motor swap with a 04 5.3 after blowing up the 99 motor and it still does it. I don't know what it could be and sorry for this thread being so long just trying to give detail. Thanks for the feed back
Old Mar 12, 2012 | 5:39 AM
recondrill's Avatar
did you swap the PCM with the motor sway? other common causes can be a dirty throttle body and bad O2 sensors. clean/replace is a cheap attempt to fix. Some motors like certain O2 sensors versus a universal one. hope this helps.
Old Mar 12, 2012 | 8:15 PM
No its the same PCM, the throttle body is definately clean because i had to use the same throttle body and intake because the 04 had an electric throttle body, so i cleaned the hell out of it. Is there anyway i can test if the PCM(this is the computer?) is bad or the 02 sensors are bad before i go replacing them.
Chupp
Oct 27, 2021 7:59 AM
TDSubMan
Mar 22, 2016 8:40 PM
ru_1980
Mar 6, 2010 10:49 AM
Scany
Sep 11, 2008 3:10 AM
cblu007
Jul 26, 2007 8:11 PM
