Rubbing noise on front wheel in AWD or 4WD 2006 Silverado
Old Feb 8, 2011 | 6:42 AM
WF85's Avatar
Default Rubbing noise on front wheel in AWD or 4WD 2006 Silverado
I have a 2006 Silverado Z71 Crewcab truck (approx 55k miles) that has developed a strange problem that my mechanic cannot figure out and neither a drive train specialist without opening the entire transmission case etc.
After a wheel bearing needed to be replaced over the summer, now in winter when I tried to select the AWD (or 4WD) option a friction/rubbing noise starts at the front left wheel; to the point where the truck will pull to the left. The truck does get into 4 wheel drive; they tested this on the snow/ice, but this noise will not go away. The noise is significant enough to not use the AWD or 4WD option; something might really break....
When the selection is changed to 2WD again, the noise and pulling immediately stops.
Any suggestions how to remedy this? I am hesitant to bring it into another dealer because of $$'s.
Any help/suggestion is appreciated!
Old Jul 31, 2012 | 11:28 AM
bpbrun's Avatar
What was the result of your problem? I have a 2002 Chevy Avalanche with a rubbing noise that appears to be coming from the front left side, but only happens in 2WD. As soon as I put it in 4WD, the noise appears to stop or at least disapate. All brake rotors and pads were replaced recently and did not make any difference.
Old Jul 31, 2012 | 3:45 PM
SweetEmotion's Avatar
Sounds like a front axle shaft, or Front Diff. may have been damaged when replacing wheel bearing. You could try jacking all four tires off ground have a buddy get in truck and select 4wd and put into drive and give it some gas while your underneath and start checking for noise outta your F diff
Bigdaddy95
19
Sep 3, 2020 5:50 PM
jonathanharbaugh4@gmail.com
Mar 1, 2014 9:03 PM
auctionx
Jul 11, 2009 9:49 PM
DPLarson
Mar 24, 2009 11:32 AM
swatson1
Oct 18, 2006 1:09 PM
